Multiple plots won't display at the same time
I have 3 plots in my VI, all from 3 different sources, however when running the program, only 1 will work at a time. I've looked on similar issues on the forums but couldn't find a solution that works for me. Any help is appreciated.
(873 Views)
Hi Jobar,
Which error(s) do you get when you try to run your VI? Did you read the error explanation?
Which DAQ hardware do you use?
Simple solution:
Instead of using 3 DAQmx task to read 3 channels of the very same module you should use only one (1) DAQmx task for all 3 channels…
(844 Views)
