Multiple inputs on one graph,how can i select the channels i want to see?
I'm using Labview 7.1. I'm monitoring multiple channels on one graph. I don't want to see all of the channels at once. Is there a way I can select the channels I want to view, while the programs running?  I would like to be able to switch which channels I'm viewing while the program is running. Thanks for any help given. Its much appreciated. Smiley Happy
(3,882 Views)
Just color some transparent using property nodes.
(3,880 Views)
Here's a simple example of what I had in mind (LabVIEW 7.1).
(3,873 Views)
As an alternative this is something I have just cooked up for use in my current app. It too uses a property node but uses the visible property as well as allowing to change the plot names
(3,855 Views)
