05-16-2016 01:26 PM
My project is using multiple copies of lvanlys.dll. This is causing build conflicts. Does any know the solution to this?
Solved! Go to Solution.
05-16-2016 01:34 PM
05-16-2016 02:05 PM
I looked up lvanlys.dll but did not find a solution.
05-16-2016 02:26 PM
Rename the dll file as part of the build (via the prefix option) for dependencies. You'll effectively have multiple copies at run-time loaded into the process memory space but no conflicts.
05-17-2016 03:23 PM
Ok, I will try this. thanks. I will let you know how it works.
05-24-2016 10:21 AM
We mass compiled, created packed project libraries and removed unused (downlevel) code from disable structures. What ultimately helped was to update to the VISION driver on the target PC.
More info in this thread
So I am not certain what exactly fixed the multiple copy issue but I think just getting the code cleaned up helped. Now we no longer have multilple copies of lvanlys.dll.
Thanks for your help.
