Multiple USB devices with LKIF.dll
I am successfully using a single USB Keyence LK-G3001 laser displacement controller with 2 heads and making function calls to LKIF.dll
The next step is to implement a second controller.
According to Keyence, the LKIF.dll will only support a single device. They suggested disabling the 1st USB port and then enabling the 2nd port.
How can I programmatically
  determine which device is attached to which port?
  enable/disable the USB port?
(4,316 Views)
If you're running on a Windows machine you can try using devcon. It's a command-line based utility. For other operating systems you would need to use the old Google to find an equivalent utility.
(4,311 Views)
