07-31-2015 01:19 PM
I have written a vi (attached) that sweeps voltage from a Keithley 2450 in conjuction with an Advantech USB-4761 relay to automate the measurement of various devices in order. I want the current/voltage measurements from all device to be graphed on one plot in distinguishing colors but have not been able to find a way to do so. They are all being graphed as the same color. I tried adding and displaying multiple plots to my XY-graph (Plot 1 is red, Plot 2 is green, etc.) but all my graphs still registered as Plot 0 despite this change, and I was not able to distinguish one device's measurements from another. I also experimented with the Mixed Signal Graph option and had similar issues. Does anyone have any suggestions?
Thank you!
08-03-2015 11:44 AM
Does anyone have any ideas?
08-03-2015 05:37 PM
Here is a forum post that goes through a very similar situation. The hardware is likely different, but since the issue is in the graph that should not matter.
http://forums.ni.com/t5/LabVIEW/How-can-I-plot-multiple-curves-using-the-XY-graph/td-p/252597
Also, here is a paper and an example that can be helpful.
http://zone.ni.com/reference/en-XX/help/371361K-01/lvconcepts/types_of_graphs_and_charts/
http://www.ni.com/example/27627/en/
Hope this helps!
