Right-Click on the control/indicator or the node in the wiring diagram
and choose "Create" -> "Local Variable". This will create a node in the
wiring diagram on which you can right-click and change to "Read Local" or
"Write Local". You can use as many of these in your diagram as you like.
Be careful with these, however, since changing their values in code can have
unexpected side effects (race conditions). If you are creating a local
variable from a Boolean, you cannot set the Boolean to "Latch when
released"-- there are ways around this, though.
--Doug
brettnick@my-deja.com wrote in message <7r64f5$ni3$1@nnrp1.deja.com>...
>I have a VI and I need to reference a control/indicator multiple times
>(like the error control). How do I make another copy of the
same
>control somewhere else in the wiring diagram?
>Can the copied control be either a control and an indicator?
>Thanks in advance,
>nick
>Sent via Deja.com http://www.deja.com/
>Share what you know. Learn what you don't.
