Multicolumn listbox with dropdown style selectable values
Hallo, In LabView 2013, is it possible to set a multi-column listbox cell to select values ​​from a dropdown list (ring)?
i.e. in a Listbox like this:
To have Reference column cell's value selectable from a dropdown list like:
(284 Views)
Yes, with some work and the combination of a text ring.
  1. You can hide the text ring until the user clicks a cell in the listbox/table.
  2. From the mouse down event, you can get the cell size and position, then use that to resize the text ring and change its position.
  3. Populate your text ring.
  4.  Make the text ring visible.
  5. After the user chooses a value hide the text ring and update the listbox/table.
(230 Views)
Checkout DataGrid for LabVIEW https://forums.ni.com/t5/QControl-Enthusiasts/Datagrid-Example/td-p/4093086
Santhosh
Soliton Technologies
(215 Views)
Is it available for LV 2013?
(202 Views)
