Multicolumn Listbox Keyboard Navigation Bug
Attached is a vi demonstrating a bug I observed in January 2008 with LabVIEW 8.5.  Now in LabVIEW 10 I see that this issue still exists.
The problem is observed while setting the multicolumn listbox value programatically, in effect selecting a row programatically, and then trying to navigate to a different row in the listbox using the up/down arrow keys.  Navigation does not start from the currently selected row.  Instead it starts from the row that was selected prior to the programatic change to the multicolumn listbox value.
Message 1 of 11
(3,153 Views)
Thank you for reporting this behavior. I have created a corrective action request #255312 for R&D to further investigate.
Stephanie A.
Americas Marketing Manager
Message 2 of 11
(3,134 Views)
I'm still getting the same behavior in 2014...Smiley Sad
CLA, CTA
Not my tempo... AGAIN!
Message 3 of 11
(2,793 Views)
Hey everyone,
This behavior was additionally tracked with CAR 448710 and is now fixed in LabVIEW 2015
Message 4 of 11
(2,650 Views)
Are you sure this was fixed in 2015? I just opened the example in 2016 and I'm still experiencing the same problem.
Message 5 of 11
(2,364 Views)
I am actually seeing the same thing in 2016. We will investigate this internally.
Eric
Applications Engineer
Message 6 of 11
(2,329 Views)
This is also the case in LV 2015.0.1
Any updates? The current search feature in my program acts weird because of that.
Message 7 of 11
(2,261 Views)
Accepted by Larry_Stanos
There is a KB that provides a workaround for the behavior you're seeing.
(How Can I Make Persistent Programmatic Changes to the Value of a Listbox Control?)
http://digital.ni.com/public.nsf/allkb/61D1AA87092BBC4C86257ED2005B1EC5?OpenDocument
Message 8 of 11
(2,253 Views)
That worked. Fantastic, thank you.
Message 9 of 11
(2,238 Views)
The solution link is broken - can you share the method that worked for you?
Message 10 of 11
(391 Views)
