02-13-2019 11:18 AM - edited 02-13-2019 11:21 AM
maybe due to the fact you're reading mV?
and what is the difference? (If you have data in the graph, use Make current values default and than save the vi with data in the graph 😉 )
02-14-2019 03:05 AM
Hello Henrik,
Can you explain more to me? I didn't get your point.
02-14-2019 03:27 AM
For example, I tried to send a sinusoidal signal. But, I don't see any sinusoidal on LabVIEW
02-15-2019 09:12 AM
first include a clear serial buffer in the loop before writing 'C??' and reading a new set of data.
you read with approx. 10Hz .. what frequency is your sine? I suggest 1Hz or less.
02-15-2019 10:05 AM
Why should I add a clear buffer won't it delete the command sent to the Unit for data acquisition?
02-18-2019 03:22 AM
I'm doing a project where I created an ECG board that generate the signals shown on the oscilloscope in the picture below.
Then I'm going to acquire these 3 signals through a module HB628 to visualize it on LABVIEW. So, my problem is I can't see the signals on the graph in my VI HB628check01(01).vi attached below.
What do you think about the method I used? how should I fix it?
thank you.
