MsiError 1627 during install application built with labview 2009
I tried to install an application built with labview 2009, i have this fatal error "MsiError 1627: 1: 2727 2: UsFile".
Executable works fine whereas installer doesn't work !
UsFile is an Lvclass. i don't understand why i have this message.
thanks a lot.
(4,429 Views)
Try to delete the installer from the project and create it again but do a test with a simple project first and then with your project.
If this not solve the issue, perhaps there is a problem with your MS Windows Installer service, it may be deactivated or corrupted. Here is an installer for 3.1 version of this service, from Microsoft : Windows Installer.
Let me know what happens.
Steve M.
(4,411 Views)
Accepted by topic author pca.eurosonic
Hi thanks for answer,
I didn't delete the installer. it was not MSI desactivated or corrupted.
Problem is in File source : ProgramFilesFolder wasn't as the same as My application. So i refreshed that (the folder UsFile not appeared in ProgramFilesFolde)
Now, it works!
thanks a lot Bye
(4,397 Views)
I had the same error.
I had not set the default installation directory in the destination category in the application builder.
-Marius
(4,166 Views)
