Move item from bottom to top of another item
I am using LabVIEW 2015.
I have a momentary button and corresponding LED. The LED is made slightly bigger than the button and placed below the button. So when button is pressed, button lights up until released, while LED lights up and stays lit till next button press; only the border of the LED is seen because button is on top of LED.
My issue is sometimes the button is below the LED. How do I move an item to be on top or bottom?
Thank you
(2,772 Views)
In the front panel toolbar there are Align Obects  and Distribute Objects functions, including vertical gap or compress. Also when the VI is not running, you can click the button so that it is in the lower position and that way you can see if the button is overlapping the LED indicator.
(2,767 Views)
Accepted by topic author CRonnenbergh
Next to that is Reorder. I am NOW using "Move To Front" or "Move To Back".
Thank you
(2,757 Views)
