03-28-2007 03:17 AM
03-29-2007 11:00 AM
Hi King1
I am currently working on this issue and will be in contact with some information when I have something.
Thanks for your patience
Best regards
Rob L
03-30-2007 06:00 AM
Hi King1
I have been able to modify an example VI which came with LabVIEW v8.2 which uses the 3d picture control. I have added an event structure to the code which allows the user to pause the rotation of 2 objects in the picture display area. I have added notes to the block diagram which should help in describing its behaviour. the file is attached with this post.
I hope this is of some help, there are a few more 3d picture examples in the LabVIEW example directory which might also be of use.
Best wishes
Rob L
12-05-2021 08:04 AM
Hello dear colleagues
Would you be so kind to share code example for mouse down (and not only zooming) and programmatically action for this mouse down.
For example I have multiple cones (in my case their 90 pieces). So that I'm left-clicking on any of the 90 cones then I can increase (or do some other action with the selected object) this cone or other object selected by the mouse
