Mouse Scroll does not work in case structure case drop down on Windows 10
though this is an old post, I have found the solution for this:
It depends on the mouse settings in Windows itself. In Windows 10 the setting 'Scroll inactive windows when I hover over them' is per default switched on. If you switch this setting off, you can scroll again through case structure dropdown menus.
See also this NI KB: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000fzh8SAA&l=en-US
I hope this information still helps somebody.
Best,
Kilian
M.Sc. Kilian Fröhler
National Instruments Germany
Message 11 of 12
(286 Views)
thank you for this, your hint has helped to solve the problem "inside" LabVIEW. But however, I noticed just now, when I click windows 10 start button, I cant scroll down to go to any apps which not visible. Maybe NI needs to fix this issue?
Message 12 of 12
(220 Views)
