Motor inertia of dc servo motor
I working on to calculate the total inertia of the motor with a pulley set. How to find the motor inertia from the specification data given with the motor?  How about armature inertia ? Is it very important to the inertia of the whole system ?
Shawn
(3,337 Views)
Hi Shawn Chew,
Thank you for contacting National Instruments. I think this post would be better suited to a mechanics forum rather than this LabVIEW forum. LabVIEW is a graphical programming environment and language and this discussion forum is devoted to solving problems of that nature.
I have however, found a couple of external links which I think maybe of more use to you in answering your question.
This is a forum for Engineers but specifically relates to Electric machines. I would try posting your question again there to see if anyone could help. Alternatively, try this link for another mechanical engineering forum.
I've also included this link which relates to a paper about calculating moments of inertia of a variety of different AC/DC machines.
I hope this helps,
Many thanks,
Andrew McLennan
(3,254 Views)
