Jonas Lybecker wrote:
> I have a problem with VISA and GPIB-ENET controllers under UNIX.
> I can only access controllers numbered 0 to 9 when I add more
> controllers numbered from 10 and on they are not found as a resource
> with VISA.
> Anyone experienced the same?
> I have extended the number of boards possible to configure with ibconf
> to 128 boards and devices
> Regards /Jonas
> Ericsson Radio Systems AB
> Sweden
> Sent via Deja.com http://www.deja.com/
> Before you buy.
Acording to the ReadMe in /opt/NI-488.2
you can use ibconf to create a new /etc/gpibrc that will support 128 boards.
This is for Version 1.2 , it requires you to be superuser.
Try checking this out, not sure if it will help but I would be interested in
knowing since I may be doi
ng this in the near future.
Kevin Kent
