12-24-2006 11:36 PM
12-27-2006 10:39 AM
12-27-2006 02:49 PM
12-27-2006 03:45 PM
12-27-2006 08:38 PM
Hi Brian,
The reasons we dont want to use the controllers are:
1)The controller is very old and it doesn't have the technical support for that device
2)The Furnace doesnt have a cooling unit, so the alarm is ON in all the stages and also the furnace has 3 modes- Purge, heat and cool. so I tried configuring the alarm in the controller but due to purge mode, there is a very large variation between the setpoint temperature and process value temperature and so the alarm is ON in all the stages.
That is the reason we dont want to use the controller input.
So if I go for USB thermocouple input device, what are the other hardware & software we require.
I worked out on the tutorial Chetan had sent me but didn't find anything related to the triggering and time delay, Can you tell me how to enable the alarm only in the soak stage.
Thank you very much for your time
12-27-2006 09:06 PM
First, I am going to recommend getting a new controller. A Eurotherm 3504 or 2404 will do everything you want, and you can get it with Modbus comms. There are Labview drivers for that. If you don't want to go that route, then here goes:
I have used this before with Labview: http://www.measurementcomputing.com/cbicatalog/cbiproduct_new.asp?dept_id=480&pf_id=1692&mscssid=TAU.... It would only read temperatures, and has no built in logic. You will only need thermocouple wire or thermocouple extension wire to connect it to your existing controller. You can piggyback off the controller T/C terminals.
You could write a program in Labview that graphs temperatures and/or writes them to a text file. You could have the program wait for the temperature to reach 300 degrees, then enable your alarm logic. Store the time that this occurs into memory or a file. Disable the alarm function after the soak time has elapsed.
What to you want to happen when an alarm occurs? Send an email? Flash something on the screen? Trigger some external device.
12-28-2006 08:22 AM
Thanks Brian,
Yesterday I worked out on the Labview tutorial and was able to figure out how to read the DC voltage peak to peak in certain range, hope that would be the same for the temperature, if it is the same I want to find out how should I do the logic part for enabling alarm after the temperature reaches 300 degrees celsius, can you be more specific.. please.
For the alarm I want to trigger an external device or we need some sort of sound signal to alert the staff on the floor.
Thank you one again
12-28-2006
10:49 AM
- last edited on
04-04-2024
11:54 AM
by
Content Cleaner
Hello Brian,
In terms of the hardware, if all you need to do is take readings from a thermocouple, I would recommend the USB-9211A (an NI 9211 module in a USB carrier). If you also need to generate a digital trigger signal based on some alarm condition, I would recommend using a CompactDAQ chassis with an NI 9211 module for thermocouple measurements and a digital module for digital output. There are a few options to consider for the digital output, but if you need to generate a 0-5 V TTL signal, the NI 9401 would probably be your best bet.
On the software side, you will program your application using the VI's and/or functions provided by the NI-DAQmx driver. The best place to learn about NI-DAQmx is the Getting Started portal. Start out by looking at Basic Programming with NI-DAQmx and then Using the DAQ Assistant. This should help you to understand how to program your application.
Good luck with this project, and let us know if you have any further questions!
12-28-2006 11:21 AM
12-29-2006 11:10 AM
