Momentary On-Off-On Front Panel Toggle
Has anyone created an FP On-Off-On momentary toggle switch (preferably horizontal)?   I am testing a piece of equipment and need to indicate this action on the FP.
Message 1 of 10
(4,056 Views)
Just change the Mechanical Action of any switch to one of the latching types
Message 2 of 10
(4,035 Views)
I think the question is more complicated than this.  It sounds like a 3 position switch, where you can click on the right or left, but then it snaps back to a center off position.  This might require special graphics and programming to implement.  Probably an enum rather than a boolean since it has 3 states (left on, right on, center off) rather than the normal 2 for a boolean (on or off, true or false.)
You'll probably need an event structure to handle it.
Message 3 of 10
(4,021 Views)
You're right.  I think I misread the question.
Try this thread
Message 4 of 10
(4,019 Views)
Thanks for the reply, I guess I wasn't specific.  I know how to make a momentary switch. What I need is a three position toggle.  Right-On right, middle Off, left-On left.  The equivalent of an SPDT (Single-Pole, Double-Throw) switch in electronics.  Where the right and left positions are momentary.  That is the 'big' challenge.  I would be satisfied at this point if I had a three-position toggle indicator with the same action.  I have two BOOLEAN controls: right-on/off and left on/off that I need to have control a single three-position toggle indicator.
Message 5 of 10
(4,014 Views)
That link Manchoo posted is excellent.
It is a combination of two switches, and they are grouped together to keep them attached.
All you need to do is change the mechanical action on the lower one.  And change the pictures on both so they reflect a horizontal switch.
Oh, and change the output logic.  This one ORs the two results to be a single Boolean.
Message 6 of 10
(3,999 Views)
How would you activate a three position toggle?  IRL, you push it to the left or to the right and it snaps back.  However in software, that's not really feasible to do unless you CTRL+click to go left and CLICK to go right (or some other modifier).
aputman
Message 7 of 10
(3,998 Views)
You click right side to go right.  Click left side to go left.  With the autosnap back, you the return to center is automatic.
Message 8 of 10
(3,995 Views)
Yeah I just saw the link.  That's quite genius.  Very nice, Altenbach.
aputman
Message 9 of 10
(3,992 Views)
If you just need an indicator, use a Picture Ring with a few carefully chosen images:
Message 10 of 10
(3,959 Views)
