Modules not detected in NI-PSP
Hi all,
I have a issue regarding detection of C_RIO 9068 I/O modules in LabVIEW.
My modules were successfully detected in NI-PSP as well as Distributed system manager when I declared it as "Scan interface" in the project explorer.
Once I tried changing it to "LabView FPGA Interface". Now , even if I try to change it to " Scan Interface mode" , my modules aren't detected in NI-PSP as well as Distributed Systems Manager.
I even tried repairing the LabVIEW and the Distributed system manager, but of no use.
Kindly help me out!!
(1,134 Views)
Hello  hari2323,
Did you try to use NI MAX for checking modules?
If you haven't solve the problem yet, I suggest you to check it from NI MAX.
Again, no any detected modules after checking from NI MAX? Then in this case you should uninstall and reinstall your drivers.
It may be resolved after reinstalling.
_____________________________
Best regards Lyudvig Hovsepyan
(1,025 Views)
