08-02-2019 01:14 AM
Hellow i download the NI Vision Acquistion software but still i dont find the vision and motion option in my lab view please see the attached file
Help Please
08-05-2019 02:45 AM
Check the version of NI Vision and the version of labview. For example, if you use LabVIEW 2013 and install Vision 2011, it will not work.
08-05-2019 04:29 AM
ni vision version and labview version should be same
Please see the attached image, i have NI Motion of 2018, This issue may be by NI motion 18 ?
and i
08-05-2019 05:50 AM
Did you installed for the same 64bit? Ensure whether it has 64bit or 32bit.
Go to NI License Manager and be sure your software is Activated.
08-05-2019 07:36 AM
What version of LabVIEW are you using? You seem to have NI Vision installed, but not NI Motion. I now cannot find the reference, but I recall seeing, somewhere last month, a notice that NI was stopping development (and shipment?) of NI Motion. This is more likely to be an issue if you are installing LabVIEW 2019, I would think ...
08-05-2019 07:40 AM
am using labVeiw 2019, I have installed NI motion But it supports Labveiw 2018
08-05-2019 08:12 AM
try to use labVIEW 2018
