03-27-2007 01:16 PM
03-29-2007 06:52 AM
Hi Maldini,
Thank you for posting to the NI forums. Is the VM Ware PC using the same operating system as the development PC? Also, are you using DAQmx 7.1 on the development computer, or are you using a more recent version? When distributing applications, the driver version on the deployment PCs must match the driver version of the development PC.
If this is already the case, then you shouldn’t be receiving any of these error messages. There are few things that may fix this problem.
With Windows XP and LabVIEW 7.1, you are able to use the latest version of DAQmx, which is currently DAQmx 8.5.
After going through these steps, please post back if you continue to have problems.
Ed W.
03-29-2007 07:29 PM
03-30-2007 05:55 PM
In LabVIEW 8.0 and later, building distributable applications requires the use of a LabVIEW project. You can create the project by selecting File >> New Project…
Once the project is created, you can add the
For clarity, I’ve attached a screenshot of this. Post back if you have further questions.
Ed W.
