06-30-2009 05:10 AM
Hi Zhijun,
Yeah, your code works.
On giving it a little thought, I think the reason could be that I am using 2 channels of the daq and using the split signal to split the pulse and breathing signal. THis could be a potential problem. IS there a better way to separate these signals, if this coud be a problem?
image attached
06-30-2009 08:11 PM
Hi Jaspal,
I think you could just use "Convert from Dynamic Data" to convert the output from DAQ Assistant to 1D array of waveform. If you have two channels, the array will include two elements.
BTW, we have a user group for biomedical applications: http://decibel.ni.com/content/groups/biomedical-user-group You could discuss the related topic there and also could share your biofeedback applications if possible :).
Thanks!
Zhijun Gu
