06-19-2017 01:09 PM
I am totally new to NI VISA. When I tried to run the program( daq programing; using labview 2014; NI9215;) the error message (code:)1073807202 keeps poping up saying a that error occurred at VISA Open in Agilent 33XXX series. So I followed the solution provided on the ni.com for this code and tried to start the fixing on the remote system section. However I just got a blank page for this remote system root directory. I tried to create a new device manually and I got the message saying "The device at this address is not supported by the drivers installed on this host". I don't quiet understand this, which drivers does it talk about ?
06-20-2017 03:36 AM
Occassionally with Agilent kit, I have had to install the Agilent IO Libraries to make the devices play nicely - most often the USB devices.
Could it be a USB driver issue on the host PC? If so, install the Agilent IO libraries from the Keysight website - but be sure that the VISA is set to secondary VISA so as not to conflict with NI VISA if you haven't already got them installed.
James
