04-05-2022 08:05 AM
I am trying to log data to a USB drive using a cRIO-9040. I have found some examples that I try to follow but all of the examples tell me to use functions from the "File I/O" folder in the block diagram pallet. The current issue is that I do not have a "File I/O" folder in my block diagram pallet. I have attached a jpg showing what I do have in my block diagram pallet. How do I move forward so I can save data from my FPGA Target using my cRIO-9040 and be able to retrieve that data using a USB flash drive?
04-05-2022 08:19 AM
Because you are on the FPGA side of the cRIO, this one cannot write to USB drives, you need to implement the file I/O code in the RT side of the cRIO if there is one (I am not familiar) or implement it on the Host side.
04-05-2022 08:20 AM
You have to do your File IO on the cRIO. At the moment, you're trying to do File IO on the FPGA.
You have to get your data from the FPGA to the cRIO using FIFO or reading control values.
