Minimum of data interpolated with Spline Interpolant
Is there a fast way to obtain the minimum of data interpolated with the LabVIEW Spline Interpolant function?
Thanks for any help.
(2,974 Views)
Yes.  If I'm understanding you correctly, you just want the minimum second derivative returned in the 1-D interpolation array.  This can be done with the Array Max and Min VI found on the array palette.
Craig D
(2,953 Views)
Thank you for your reply.
The Array Max and Min would work if I interpolated the data with the Interpolant, and the precision of the minimum location would be determined by how many points I use to interpolate.
However, I was thinking there may be a way to functionally use the Interpolant to determine exactly what the minimum value should be instead of actually interpolating into an array and finding the minimum. I wish I knew how the spline fit works.
(2,948 Views)
