01-08-2008 03:56 PM
01-08-2008 04:54 PM
Maybe chop out sections of the image and replace it with a custom control that you have an image of the breaker. Also, you could just place a control with the image on top of the breaker. This link will give you some instructions on how to create a control with an image.
http://zone.ni.com/reference/en-XX/help/371361D-01/lvconcepts/custom_cont_ind_type/
Use the Control Editor window to customize controls and indicators and to define the private data control for a LabVIEW class. For example, you can change the size, color, and relative position of the elements of a control or indicator and import images into the control or indicator.
01-08-2008 04:56 PM
Sure. You cold drop an picture image onto the front panel. Set it's Z-order through the Reorder button so it's all the way in the back.
You can create boolean buttons. Customize them so that some or all of their parts have a transparent color so the background graphics show through.
You can also use picture controls to display pictures on the front panel and do special customization so things like mouse down and mouse up could change the appearance of the picture, though I haven't played with that myself yet.
01-09-2008 01:35 AM
01-09-2008 06:07 AM
Although the Picture control can hadle special cases like "just switch when you click the trip bar" but an easier approach uses the method tst showed in his "External Resourse Nugget"
It let me do this!
(Yes it changes appearence when pushed in!)
Do you want it to be more real than that?
Ben
01-09-2008 07:24 AM
