Micro-Nuggets !!! ~~~~ Post 'em if you got 'em
here is the example using strings
Message 51 of 368
(6,721 Views)
But you should be very careful when doing this with strings, because it has specific behaviors which may be unexpected such as being case sensitive.
___________________
Try to take over the world!
Message 52 of 368
(6,709 Views)
Also, don't get bit by the range not being inclusive when dealing with strings.
Message 53 of 368
(6,705 Views)
Thanks for the warning guys...  🙂
I should have mentionned those with the examples...
I have not used this with strings...  Just wanted to include them from an interest point of view..  🙂
Message 54 of 368
(6,701 Views)
[edit] Hmm beat me to it.  I should have flipped the page firstSmiley Very Happy it would have saved me some wiring
"Should be" isn't "Is" -Jay
Message 55 of 368
(6,698 Views)
<oops>
Jim
Message 56 of 368
(6,666 Views)
Yes, we do have to be careful with the string ranges in cases, they behave like "In Range and Coerce", except there is no graphical representation showing that "a..c" doesn't include the "c", the way that the "IR&C" shows you. It is also counter intuitive that numeric ranges of a case statement, i.e. 2..5, include all the values from 2 to 5 inclusive, sort of like rules of spelling in English, "i" before "e", except after "c" or on alternate Tuesdays in months that have an even number of days.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 57 of 368
(6,586 Views)
Hi all. Smiley Happy
I have made a VI that gets a list of the ClassNames and ClassID's of Block Diagram items... i.e. for you Scripters out there.
I have placed and labeled dozens of items on the block diagram. The generated list is shown on the front panel. If you want to know the ClassName for an item not shown, just put it down and hit run.
Preview below .. VI attached. 2010. You'll need Scripting turned. I've used OpenG for a few array operations, but it's not a big deal.
[EDIT: Deleted image and VI by request, see new post, message 61]
Richard
Message 58 of 368
(6,512 Views)
Can you elaborate on your diagram comment for the need of two FOR loops. Since your are indexing over the same array, shouldn't the iterations always match?
Message 59 of 368
(6,503 Views)
When I first found my destiny-changing floppy disks containing LV 5.0 I bought a copy of "LabVIEW for Everyone". Forced myself to read it page to page, cover to cover. Did every exercise. I normally don't do that. Glad I did.
PaulG.
Retired
Message 60 of 368
(6,490 Views)
