Micro-Nuggets !!! ~~~~ Post 'em if you got 'em
@JÞB wrote:
CAUTION: the attachment above is saved with "Run When Opened"=True!
(continuing my shameless plug)  My LabVIEW Tray Launcher I linked to earlier can take over and if you try to open a VI that is set to run when opened, it will prompt you to ask if you actually want to run it, or just open it without running it.
Message 341 of 368
(4,977 Views)
@sebster wrote:
I use this vi that I found a while ago. Simply run this (double-click it) whenever needed.
I take no credit for it whatsoever. If it is yours, I salute you and would like to say a big thank you for it. It has got me out trouble quite a few times during development. I hope you don't mind me sharing it here.
Darren posted a nugget on this some years back if you wanted a different version.  His is also set to "run when opened = TRUE" and is password protected.
Message 342 of 368
(4,953 Views)
Ctrl+T will show the connector pane terminals when you are in the Icon Editor.
Edit: if it was an obvious one for everyone, sorry, I just discovered it right now accidentally 🙂
Message 343 of 368
(4,885 Views)
I've never once heard of anyone mention this feature.  I don't know if everyone except you and I knew about this, but it certainly isn't an obvious feature.
Message 344 of 368
(4,861 Views)
Filter Search Results.  I've known about this for a bit, but noticed it is an official feature in >= 2016.
Lets say I have an typed enum and I want to find all times that there is an instance of this enum as a constant with the value of "read device".  I can create a search for the string "read device" but that will bring up all times that is used on controls, indicators, VI description, comments, etc.
Now I can type "enum constant" into the filter and only find enum constants that have the text "read device".  There's limitations in this case like it will find all enum constants with "read device" and not just one strict type, but still it narrows the search.
Message 345 of 368
(4,850 Views)
Thanks for this shortcut! This used to be on by default, and the icon editor also used to show where the wires terminated, with a small gray x. Yes, the wires actually terminate at a particular spot, and this can be useful to know when designing small icons. It should be the center of the terminal, but it's no longer shown.
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 346 of 368
(4,843 Views)
Is there even a menu item or button that lets you toggle this or is it actually just Ctrl+T?
To add to the list of undocumented features, if quick drop is open you can press F3 and it will center it on your main monitor.
Message 347 of 368
(4,806 Views)
Actually it is just in the Edit menu, but somehow I never paid attention to this part when editing icons 🙂
Message 348 of 368
(4,798 Views)
Sometimes it's nice to have elements on the front panel for debugging, and then scroll them off screen to make sure the user doesn't see them. To make sure you don't forget to scroll back to the original position (or just to make it easier), you can set the origin back to 0,0 every time the VI is run. Place this VI in the block diagram and the caller will automatically go back to the origin when run. (I have not tested with multiple panes).
LabVIEW 2016
Message 349 of 368
(4,466 Views)
I will take no credit for this VI but NormK uses the attached VIs in the TLB' architecture which has some additional functionality (it also works by just putting it on the BD like yours). Hopefully that saves you writing additional functionality yourself.
Also, if I remember correctly, there is no need to close panel references as they inherit from GObject and will be a non-op.
Message 350 of 368
(4,453 Views)
