Method of sending format information of the character String Controls to the clipboard.
I want to send the format information of the character String Controls to the clipboard (RichTextBox).
Format information is font color, font size, font type.
It can not be done with the method which writes to the standard clipboard of LABVIEW.
Is there a way to send it from the prompt node of the String Controls to the clipboard (RichTextBox)?
I need your advice.
(4,250 Views)
Accepted by topic author KKCeng
I don't know if this answers your question. But this might get you headed in the right direction.
If you hover over the property node with the (help dialog) open it will reveal the .net class type that is required for those properties. Then you can use a .net constructor node to generate the necessary properties. (be sure to close the reference properly here (I left some open))
You probably want a 2015 snippet 😉
(4,163 Views)
The principle is good. Just be aware that the LabVIEW FontSize is in pixels while the .Net Font Size is in em.
https://www.w3schools.com/tags/ref_pxtoemconversion.asp
Rolf Kalbermatter  My Blog
(4,156 Views)
Yea, I did overlook that. Thanks!
(4,153 Views)
Thank you for your detailed advice.
2015 Snippet too
(4,127 Views)
