11-06-2018 07:59 AM
I've started to using Labview NXG.
For a project i want to display 2 signals in one chart, the raw-signal and a filtered signal at 75 Hz.
In labview 2016 it worked well with "merge signals", but in NXG I dont find the alternative.
THX,
Dries
Solved! Go to Solution.
11-06-2018 08:08 AM
Hi Dries,
Well, in LabVIEW2016 you could use a BuildArray node as well, no need for ExpressVIs here.
Does BuildArray exist in NXG too?
11-07-2018 03:55 AM
I can confirm that Build Array exists in NXG and can be used to display 2 signals on one chart
11-07-2018 04:22 AM
Strange in my application it doesn't seems to work 😞
I putted my code in attachement.
Dries
11-07-2018 04:33 AM
11-07-2018 05:39 AM
Hi GerdW,
In attachement you find the errorcode. I can't upload the gvi, it is blocked by the forum.
In fact i started with the example "Automate Saving and Reporting Data".
Kind regards,
Dries
11-07-2018 05:48 AM
11-07-2018 06:50 AM
GerdW,
I found a concatenate checkbox and... it seems to work.
I just have to test it with my DAQ, but the error is gone.
Thx
