09-18-2017 10:19 AM
"The absolute upper voxel limit (taking into account the build extents of the 3D printer) is 76000x1280x800 = 7.7824E10"
I assumed reducing this by 8 was a rather decent start, i do hope the SGL calculations are done 1 layer at a time ... 🙂
/Y
09-18-2017 10:22 AM
>As I said, a smart ordering of operations and only operating on a single 2D output array by doing the summing in place is probably the solution.
Agreed. But I'm not getting the exact problem of these calculations. I'm not sure if OP is making this much to hard, or that the problem actually is hard. Either way, TDMS seems out of place to me... But if it "works"...
09-18-2017 10:37 AM
/Y
Agreed. Converting to a compressed boolean array is only part of the story. Ideally, the data should be saved in the compressed format (1bit/pixel) from the beginning.
In order to efficiently do the SGL calculations, we also need fast random access (read, write) to any particular voxel element, which is relatively trivial, of course. Personally, I would probably compress the bits into U32 or U64, keeping the indices smaller. (same overall memory as using U8).
(There are also edge effects if the array size is not divisible by the #bits/element and that might need to be handled).
09-18-2017 10:59 AM
Yup TDMS was just an idea I didn't end up implementing it - I was just experimenting with methods of offloading from RAM to disk and the normal binary read/write methods weren't working well for "streaming" (I guess that's why TDM streaming was better ).
@altenbach hits the nail on the head here - the elephant in the room is the 3D SGL array that I generate using the 3D U8 array. So I think the solution here might be as follows:
If anyone has any handy tips for part no. 2 (re-slicing the array and saving to disk) in a memory efficient manner I'm all ears.
I will update when I have had a chance to implement some of these ideas but it may take me a little while...
~P
09-19-2017 03:03 AM
I'm still thinking you want a 2D projection of the cube, and that's why you need the 3D array of doubles? I'll probably have to print out this entire thread and study it for a few hours...
So with a two pass strategy, you can make a 2D buffer to hold the projection, and process each individual PNG to it.
Then, use a second pass to process each individual PNG with the projection results, and stream to disk.
No need at all to hold any 3D array.
