I'm currently trying to use the "PLC OPC Client Read.vi" from the OPC.llb
Library in a while loop that samples every 200ms. I'm noticing that as i
run just this VI, the Memory usage of Labview.exe in Windows Task Manager
goes up quickly where after an hour, Labview.exe takes up some 150MB of
ram. Not good. Is there anyway around this problem i'm having? I'm not
familiar with memory-dumping VI's or strategies....
OPC.llb can be found in the \examples\comm directory.
