08-25-2001 01:50 PM
08-25-2001 11:42 PM
08-26-2001 01:40 AM
08-27-2001 09:18 AM
08-27-2001 09:36 AM
05-30-2009 07:14 PM
Hi Rob,
enclosed you will find two other solutions, simulating a radio button array based on a standard button array,
this solution use a event loop.
Version 1: Simulates Radio Buttons without "Allow False" Option
Version 2: Simulates Radio Buttons with "Allow False" Option
05-30-2009 07:46 PM
nightwalker wrote:enclosed you will find two other solutions,
Did you notice that you replied to a thread that is eight years old?
Anyway, you are using LabVIEW 8.6, so none of this is necessary. Simply use the radio button control. No code needed.
There is also a mistake in your example 1: If no selection exists, the index should indicate -1 for consistency. Also, instead of Xor, I would use " not equal". Functions the same, but is less nerdy and more obvious. 😉
04-26-2016 09:41 AM
I just want to thank nightwalker's example because it's exactly what I needed - specifically version 2 which allows to clear the selection. Let this be a lesson to everyone that in the internet, if you come across a very old thread and have something to add, it is a good idea to post and bump the thread, and you shouldn't be telling people off when they do that. (I'm looking at you altenbach!)
This post that I'm making right now, on the other hand, is completely pointless and you should be telling me off. Oops.
04-26-2016 11:37 AM
An update to a thread once every 7-8 years is just proof that LabVIEW is here to stay!
04-26-2016 11:54 AM
