04-03-2017 05:46 AM
How to measure temperature with thermocouple & 9209 module alongwith LabVIEW environment.
Please reply urgently
04-03-2017 05:57 AM - edited 04-03-2017 05:58 AM
Hi aru,
the NI9209 is a "standard" voltage measurement module with a simple ±10V measurement range. It isn't suited very well to measure µV of thermocouples! (Read the specs on accuracy and noise levels!)
That being said: wire your thermocouples to the module and read their voltage. Use an additional TC to measure temperature at the module to create some simple kind of CJC. Use both voltage signals to calculate the temperature…
04-03-2017 06:15 AM
does this NI 9209 measure mV ???
04-03-2017 07:06 AM
04-03-2017 11:40 AM
I think the answer to your question is you could read a thermocouple with that hardware, but the reading will likely jump by several degrees C, and will probably have a bunch of electrical noise making the reading not useful. Get the appropriate hardware for your sensor type, and this would be something that can read the uV range, like the 9211, or 9219
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
