Measuring Values from Two Oscilloscope Channels on the same Timescale
I'm reading inputs on two different channels on the same oscilloscope, and need to trigger a timer between when Channel 3 hits a certain value and when Channel 2 hits a certain value. I need these to both be in the same timescale, so how can I get information from only one of the graphs? Thank you for your help.
(3,203 Views)
Hi Standard,
What is your overall goal and application?
Are you using an NI Oscillicope? How have you been displaying the data from your oscilliscope? Is the data a waveform data? Could you provide a screenshot of the code you are currently using?
(3,143 Views)
What is the make and model of your oscilloscope?  The Tektronix scopes have a Delay measurement that will do exactly what you are asking for.
(3,138 Views)
