02-17-2022 10:20 AM
I've a Keithley DMM6500. In manual mode the current measurement works and I know, that the 10 amps range is not included in automatic range selection.
Current goal is to use the rear 10 amps input for current measurement with Labview but I haven't figured out where to select this 10 amps range in / from Labiew. Any hints?
Thanks in advance.
Solved! Go to Solution.
02-17-2022 01:51 PM - edited 02-17-2022 01:53 PM
Hi beato,
@beato66 wrote:
Any hints?
Read the (programming) manual of your DAQ device!
It will explain all the SCPI commands you need to use to actually do that measurement…
I recommend chapter 11&12!)
02-22-2022 09:57 AM
We already read in the manual, but didn't succeed with the driver.
In the end there was a bug in another VI...
Thanks again.
