Measurement file not getting every data hit, presumably due to not processing data fast enough
My example, which was only meant as a starting point, doesn't send the post-processing results to any file.  It only displays them on the graph.  But you could certainly modify the program to have it save that post-processed data to a file.  For the sake of our discussion, I'd recommend you save any such mods under a new filename.
One pretty easy mod would be to write the array of post-processed waveform chunks into the *same* TDMS file using a new group name.
-Kevin P
Message 21 of 21
(616 Views)
