Measurement & Automation Explorer error 0xBFF6901b
I am trying to get a Prosilica GE680 to work in MAX. When I click on Snap/Grab I get the error message
IMAQ error
Error 0xBFF6901B
Timeout
Does anyone have an idea of what could be the cause of this error? The same error code appears when I try to run the camera in LabView.
(5,683 Views)
Hi Allan,
I believe that the timeout error is either caused by the firewall or that you haven't installed the High Performance driver for your Ethernet card. How to install it is described in the lower part of the following document: Troubleshooting GigE Vision Cameras
Other interesting links:
Acquiring from GigE Vision Cameras with Vision Acquisition Software
Hope this helps.
Pelle S
Account Manager
National Instruments Sweden
(5,664 Views)
Thank you Pelle!
You were right, it was the firewall that was on. I had only put MAX and LabView as exceptions to the firewall, but apparently that wasn't enough. After turning the firewall off it seems to be working just fine.
Allan
(5,660 Views)
