10-01-2009 10:20 AM
10-01-2009 10:22 AM
10-01-2009 11:06 AM
Maybe it's time to recommend Portmon.
Run this program, then run whatever program you are using that you say works for you. Look at the information it provides. It should tell you what settings you are using and what data is flowing back and forth.
Try to make LabVIEW do the same thing. Run your LabVIEW program with portmon running to get a log of the activity there.
Perhaps comparing the two will show you what's not working write with your LabVIEW program.
10-01-2009 12:07 PM
Hi!
Have you tried a simple terminal program to communicate with the Keithly? I saw that someone suggested it a few pages back, but I never saw a post confirming that it works for you in hyperterminal or something like that.
Also, have you tried the Keithly 2000 drivers provided by the manufacturer? I found some by going to Help->Find Instrument Drivers.
I use the Keithly 2100 drivers over USB and they work great.
10-02-2009 04:04 AM
i worked with portmon, pretty cool program. Problem is still the read function, everytime when it starts i get an timeout error.
whats weird is, the first time i start the program (after an reboot of the computer) it works, and the second time same problem, maybe there is so much trash on the rs232 that nothing works further more, how can i clear the port? what could be another reason?
(i worked with an terminal, there it works perfectly....the drivers from keithley dont work, same error)
10-05-2009 10:43 AM
i did it another way.
i was writing an terminal programm in c, and imported the dll (call library function node).....now its brilliant working
anyway i wanna thank all who helped me...
best greetings
10-19-2009 04:59 AM
Hi, I try to use a Keithley 2000 DMM with a USB serial cable.
I got exactly the same issue as Raz22 (error with the readings). Everything is fine with the writing (setting the instrument in VDC or AAC or ... is working) but as soon as I perform a VISA read -> it goes in error timeout!
The behavior is correct in hyperterminal and with another PC in direct serial RS-232 mode. So the issue is really with LabVIEW VISA
Would it be possible to reuse your dll wrtitten in C?
Thanks for you help.
03-27-2010 08:00 PM
03-27-2010 09:19 PM
Same message, different username, 5 months apart.
03-29-2010 11:35 AM
Hello Ravens Fans and all,
I got the same issue when try to communicate with Keithley 2000. I am currently using LV7.1with VISA 4.6.2. The error code I got is -1073807339 ( VISA read in ke200 Error Query . vi->Ke2000 Data Read Single. vi->ke2000 User VI.vi). Does any one know how to troubleshoot this. I'm really appreciated
