Measure Supply Voltage Continuously
Hello. I am driving motor with LabVIEW and I record some data. I was recording input voltage connecting voltage probe to power supply but recently I realized that I can do this inside LabVIEW. I am using CPX400 power supply. Can someone help me me how I can record supply voltage continuously during 10 s, while I record current with current probe? Thank you
(1,159 Views)
Hi Lily,
Put the communication with your power supply in its own loop and read the data as long/often as you like (and is supported by that device)…
(1,147 Views)
Have you installed the LabVIEW drivers for your PS?  CPX Series Bench/System/ATE Programmable DC Power Supply | Aim-TTi (aimtti.com)
Maybe there are examples with the drivers that you can use or modify?
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(1,121 Views)
Hello. Yes I have installed drivers.
(1,112 Views)
Looks like there's an example in there that allows you to set some parameters and reads the output voltage.  All you have to do is put that code in a loop and connect a chart to the Measurement VI.  You'll want the Initialize before the loop and the Close VI after the loop.  Add a Wait.vi in there too, to throttle the loop speed to whatever you need.
(1,108 Views)
I don't see relevant examples for me there. Can you please show me how to put it in a loop and continuously measure voltage from the supply?
(1,069 Views)
