06-20-2015 12:19 PM
Can anyone explain to me why this does not work as expected? (10.5 and 0.5 values)
I get 5.5 and 5.5.
I checked the MeanPtbyPt.vi, all is clonable, the vi itself is set to preallocate clones. I also tried to set it to Inline, does not help. Tried C of 1 and 2, no luck. If I open Mean ptbypt while operating, I see that the SR holding the array of data is interleaved with 10.5 and 0.5 values, as if both clones use the same memoty space, but on the input I always see only ~0.5 coming in. What gives? I thought parallelism will create two clones, no?
Solved! Go to Solution.
06-20-2015 12:32 PM - edited 06-20-2015 12:33 PM
Yes, all the Pt by Pt functions are set to pre-allocate clones. You have exactly 1 instance of MeanPtbyPt.vi so you get 1 dataspace shared across all parallel iterations (Guess what, The loop iterations are not really in parallel since the MeanPtbyPt.vi will block)
This snipetteshows the difference between one and two instances of MeanPtbyPt.vi
Note: Those clones WILL run in parallel
06-20-2015 12:33 PM
Clonable means you have two different instances on the block diagram, each with its own memory space.
You only have a single instance of that VI. Parallelsim doesn't make clones.
06-20-2015 12:45 PM
Hello guys,
Thank you for your answers!
The problem with putting 2 ptbypts on the block diagram is that I have an array of N independent measurements, where N is large and variable.
Why doesn't a loop with parallelism create clones? It greatly diminishes its value then! I would have to re-write NI math libraries then 😞
06-20-2015 01:49 PM
A parallel loop that will iterate N times isn't going to be N parallel loops. It may only be a few. A N=100 loop may have 4 parallel instances that run 25 times each. Or maybe not even that perfectly balanced.
I think you are trying to force the wrong tool to do what you want.
06-20-2015 01:52 PM
@fomine wrote:
Hello guys,
Actually, a loop with parallelism (or without) CAN create clones. But you have to know the trick.
Here is an example of what you "Really Want"
06-20-2015 01:57 PM
Hi Jeff,
Yes, I went this route too. I just hoped for a simpler way and slightly cleaner BD 🙂
I saw a post there a poster suggested to do Loop with Parallelism for a very similar task the OP was facing. Decided to test it and found out that it did not work.
Thanks a lot guys for your reply.
