May I know how to use the user event
I saw a sample as the attached screen. The user event is used. I am totally new of user event.
may you give a brief explanation of it and how it used.
Thanks.
Message 1 of 10
(3,297 Views)
User events are dynamically load events, that can be triggered by your code. You can use any datatype.
There is nothing more. If you are familiar with dynamic loading events, you should have no problem understanding user events too.
Message 2 of 10
(3,280 Views)
Here and here are a couple of sources. You can also find some example in the example finder (Help>>Find Examples) or search for more online.
___________________
Try to take over the world!
Message 3 of 10
(3,259 Views)
After seen the samples, I am still not very clear of it.
Can I use code to simulate a click on a button, may you give a simple sample, thanks.
Message 4 of 10
(3,226 Views)
Hi turbot,
what do you mean with simulate a click? You can use the value(signaling) property. If you use it the value change event of the control will be execute.
Mike
Message 5 of 10
(3,223 Views)
But I tried the attached samples, seems cannot make it.
Message 6 of 10
(3,215 Views)
Hi turbot,
attached you will find an example. There is no need to use local variables. Smiley Happy
Mike
Message 7 of 10
(3,209 Views)
As mentionned by MikeS81, you must use a Value (Signaling) property node to generate an event. In your example, you write to the terminal of Boolean instead.
Message 8 of 10
(3,206 Views)
I changed to the property node, but still not work as attached.
Message 9 of 10
(3,191 Views)
No you didn't.
Ready more carefully
"Value (Signaling) property node "
Message 10 of 10
(3,186 Views)
