May I ask how to implement this logging function so that every step of execution is recorded in log.txt
Is there any expert who can write a demo for me to learn from
Message 1 of 11
(405 Views)
Every step from where?
This looks like a communication log for GPIB or VISA.
Santhosh
Soliton Technologies
Message 2 of 11
(389 Views)
yes,How can I add the SCPI instruction to the log
Message 3 of 11
(377 Views)
By writing the string to the log file!
What's the problem?
Message 4 of 11
(361 Views)
Could you write a demo for me to learn from
Message 5 of 11
(358 Views)
You want me to place a WriteTextFile function on an empty block diagram?
  • You should know how to write data to a file.
  • You should know how to use subVIs (or a QMH) to handle data/messages.
  • As you want to write "every step" you need to write "every SCPI message" to your log file...
Message 6 of 11
(338 Views)
Yes,I want to write "every step" you need to write "every SCPI message" to your log file...
Message 7 of 11
(334 Views)
Where did you got this log are you able to get the read SCPI data from your DUT?, Is the problem is only with Logging in the above format?
Message 8 of 11
(308 Views)
use a function write file everytime you call visa write.
Message 9 of 11
(296 Views)
The logging function of C#
Message 10 of 11
(275 Views)
