11-17-2014 04:32 PM
Doh. Again with going too fast. The picture below explains why all results are the same and parallelization did nothing.
Apparently, I can't subtract.
11-17-2014 04:40 PM - edited 11-17-2014 04:40 PM
Jeremy_Marquis wrote:Apparently, I can't subtract.
I recommend to use "high resolution relative seconds", because you get a negative value if you subtract wrong. Easier to notice. 😮
(You also get finer resolution and the results are in seconds instead of ms.)
01-29-2017 04:22 PM
To do some math-intensive work, am trying to figure what would be an optimal configuration to purcahse. The speed-up between Parallel FOR loop (4 cores) and Parallel FOR loop (32 cores) is only 2x.
For matrix multiply, is there a LV bottleneck for regarding the physical vs. virtual cores? Given that your machine has 8-cores/socket, might the speed-up correspond to one-socket and physical cores?
01-30-2017 09:42 AM
Hi wjdwyer,
It looks like this thread is a little over a year old, and your question is a bit different than the original question. I would recommend creating a new thread for your question, as it'll be more likely to be seen and answered that way.
