Match Pattern Syntax help
Hello everyone,
I have been using Match pattern to break down a file name. This is just a quick question, can anyone show me what Syntax combination do I use to break this line:
_Ring-0.10V_MZI1-0.00V_MZI2-0.00V_ 0.00dBm.csv
into separate substrings such as this:
Ring  0.10V  MZI1  0.00V  MZI2  0.00V  0.00dBM
I don't really care about the last part  .csv
If anyone can help that would be great! Thank you!!
Message 1 of 17
(3,578 Views)
Anything in brackets creates a class of characters, any of which will return a result.  In your case [-_] should work.  You are going to have to feed that whole string into a loop and do the match several times to get all of the parts separated.
-DR2
Message 2 of 17
(3,566 Views)
So this is what I have now. I used the syntax You suggested. But it didn't quite give the answer.
Message 3 of 17
(3,558 Views)
I used  [0-9]+\.[0-9]+   and I was able to separate the voltage and dBm numerical values
Message 4 of 17
(3,549 Views)
You can use Search and Replace String.vi instead.
Ben64
Message 5 of 17
(3,532 Views)
Do you think you can give the actual VI or make 2015 compatible? I wasn't able to open it in my 2015 Labview Version.
Message 6 of 17
(3,523 Views)
Accepted by topic author Huqs
Try this in your "string 3"
[a-zA-Z0-9\.]+
Gave me:
Ring
0.10V
MZI1
0.00V
MZI2
0.00V
0.00dBm.csv
You can strip the file name if needed as Ben said. Also, if you then need the numbers from the voltages etc, use the scan from string function with %f as the format string.
Ian
LabVIEW since 2012
Message 7 of 17
(3,522 Views)
Wonderful!! Thank you very Much!!
Message 8 of 17
(3,516 Views)
@Huqs wrote:
Hello everyone,
for your task, you could use this build-in vi directly, to split up the input string according to "-" and "_"
http://zone.ni.com/reference/en-XX/help/371361H-01/glang/scan_string_for_tokens
EDIT:
oh, I realize you should use the remove file extension vi, which ben showed in Message 5
Message 9 of 17
(3,514 Views)
Thank you to you too!
Message 10 of 17
(3,494 Views)
