Marlow SE5010
Does Anyone manage tu use a Marlow SE5010 Temperature Controller with serial Line.
I can't comunicate with it.
Thanks for your help
Rémy
Rémy CLAVERIE
Laboratoire MOPS - CNRS FRE 2304
Université de METZ & Supelec
2 Rue Edouard BELIN
57070 METZ Cedex
Tel : 03.87.37.85.41 (Direct)
Tel : 03.87.37.85.57 (Secr.)
Fax : 03.87.37.85.59
(3,645 Views)
Hi Rémy,
Are you able to communicate at all? Have you tried communicating with a simple terminal program like hyperterminal or teraterm? The commands you need to send are available in the manual for the device. You might also check with the manufacturer to see if they provide a driver.
Best Regards,
Aaron K.
Application Engineer
(3,645 Views)
Hi, Can anyone help me in acessing the Marlow SE6020 remotely.
I have connected it to my PC through Serial Port.But I am not able to access it.
Please help.
(3,358 Views)
