Make the clicking stop!
When I'm working with the Front Panel, and I click on a button or slider, I only want to move the objects around.  I hate when it tries to set values.
How can I change settings so it won't try to set values?
(4,094 Views)
Hello:
It seems you don't like the behavior of the automatic tool selection. To disable it, press the Shift key and right click the mouse to show the tools pallete. Then press on the green led to disable the automatic tool selection.
Then the cursor will always do what you want, given that you will select which tool you want to use.
Check out this link:
http://zone.ni.com/reference/en-XX/help/371361B-01/lvconcepts/tools_palette
Hope this helps
Robst
Robst - CLD
Using LabVIEW since version 7.0
(4,082 Views)
Beautiful.  I hated that.
(4,074 Views)
Of course, after using LabVIEW for a while you may actually find that it grows on you and you find using it all the time.
Check out:
http://forums.ni.com/ni/board/message?board.id=170&message.id=173865&view=by_date_ascending&page=1
http://forums.ni.com/ni/board/message?board.id=170&message.id=193305
(4,046 Views)
"Of course, after using LabVIEW for a while you may actually find that it grows on you and you find using it all the time. " [Emphesis added]
I still think I can sling wires faster without the auto-tool selection. Smiley Wink
Ben
(4,031 Views)
You just have to get used to which part of the control you need to aim at to get the move tool (the arrow). For a slider, it's the scale part of the control, not the actual slider that you move to change the value.
I've always used the auto tool, mainly because the earliest LV version I used was 7.0. I think I'd go crazy without it.
(4,017 Views)
