01-01-2013 10:23 AM
Happy new year to all.
Is there an easy way to achieve the functionality in the picture below:
I want the bold zeros to be terminals on the block diagram that I can update. Would you agree in saying the top set looks better than the bottom?
Kind Regards
Lewis
Solved! Go to Solution.
01-01-2013 11:02 AM - edited 01-01-2013 11:08 AM
Here you go
Start with the simple numeric the trick of course is to set both the BG and Boarder to Transparent by toggling (or left click and right-click) and select T for both
01-01-2013 12:00 PM
That has done the trick, thanks.
I have not seen a simple numeric before, which palette are they on? (I can only find them on quick drop).
Lewis
01-01-2013 12:19 PM
Classic>>Numeric
01-03-2013 11:45 AM - edited 01-03-2013 11:46 AM
Just as an aside and to prove the universe is run by serendipity, Guess what I needed to drop on a UI this morning.
06-26-2018 04:59 AM
Thank you for the information but i need to know the steps to make a transparent indicator (where i can find the BG and Boarder).
