Okay. I haven't noticed these problems, but here's step-by-step of what I did. (By the way, mine was a MXI-3 connected to a PXI-1011, so I also had SCXI to worry about)
Mine was installed on the Dell running Windows 2000. I was having problems with the MXI-3 recognizing hardware in the PXI chassis, so here are the step-by-step notes that I took. Hopefully something in here will fix the problem, but since that didn't happen to me, I don't know....but you can certainly give it a try.
Notes
Setting up a MXI-3 card with a PXI/SCXI chassis:
1) Remove MXI-3 software from the PC. Cycle power on the machine (the MXI-3 hardware should already be installed). Let it come up, and run MAX. Check out the properties of the PXI cards. Note the PXI bus number and the Device # of each board; you'll need this for the pxisys.ini file. If the cards are not listed in the Devices directory, select View->refresh.
2) Load a pxisys.ini file to the computer in the c:\windows or c:\winnt directory. For a PXI-1011, delete the last four slot information. Change all PCI BusNumbers to the bus number that MAX showed for the cards in step 1. Change the slot 4 SecondaryBusInterface to SCXI. Change the PCIDeviceNumber to match the device number that MAX showed for the cards in step 1. The PCI device numbers increment as the slot numbers decrement. Slot 1 has no PCI device number, since that's where the controller would reside; it should be set to NONE. Save the file. The slots you have defined in this file should now match the PCI devices MAX found. When a PXI-1010 or PXI-1011 is now setup in MAX, this file will now define the device in the rightmost slot to be the SCXI controller, so the SCXI modules can be automatically detected.
3) Run MXI-3 software from floppy to install it. Cycle the power. MXI-3 software shoud see the board, and displays a few messages. Bring up MAX. Make sure the PXI cards are still in the devices list. Run tests on them. Change device ID if needed. Highlight devices, and right click to add a device. Select PXI-1010 or PXI-1011, depending on the chassis. Select autodetect modules. Select the PXI/PCI device which is in the rightmost PCI slot from the list. The SCXI modules should now be found.
5/17/01
Mark
