05-20-2011 02:45 AM
please i am facing few problems in labview.
1- i did an Am modulation application using labview. for demodulation i used "MT modulation toolkit" but i faced a problem while wiring the desired signal to the demodulation block saying "you have connected two terminals of diiferent types" but i am not able to solving this issue.
2- the second problem was in using a lowpass filter which always show up the following error whatever are the inside parameters "Error -20023 occurred at Filter->Amplitude Modulation (AM)-demod.vi "
i would be thankful if someone can help me.
thank you in advance.
Solved! Go to Solution.
05-24-2011 04:44 AM
Hi o4enPro,
Sorry for delay and thank you for contacting us.
1. You cannot connect two different types, but you can "transform" the one to the other type. You have to build proper waveform types and/or clusters. You can see in the Context Help (Ctrl+H) which type of input data is desired on each function or Express VI. Open my attached VI to see the solutions.
2. For the error code details see the page: http://digital.ni.com/public.nsf/allkb/ABBD3A7BC25E17C8862561270058A4A0?OpenDocument
Your problem source was that: An array of data is being passed to the filter without waveform information. Again, you should build the proper data type. Solution is in attached VI.
If you have further questions, write us again.
Peter
05-30-2011 04:12 AM - edited 05-30-2011 04:17 AM
05-30-2011 04:22 AM
Hi Peter,
Thank you for your help. And please i still need your help finalizing project.
I need to substitute the "message signal parameters (f, A, P)" in the previous VI "Amplitude Modulation (AM)-demod_PeterNI" by the attached function generator "function-generator.vi".
i appreciate your help
Thank you
05-30-2011 05:47 AM
You can easily embed the generator into the modulator code, as a SubVI.
I replied you on an other thread before. Please find the example in that thread: http://forums.ni.com/t5/LabVIEW/linking-function-generator-to-AM-modulation-toolkit/m-p/1574902
I hope it will be helpful.
Peter
