02-11-2019 03:46 PM
I am trying to get the MSP-GANG programmer to verify the firmware already programmed into a PCBA. for example, if I want to verify that Rev B of the firmware is programmed into the PCBA, I can do this through the MSP-Gang GUI, you select the desired firmware image, set the MCU, etc and then press verify. If the firmware on the PCBA is Rev B, you get a pass. If it is Rev A, then it fails.
Using the dll, I cannot figure out how to accomplish the same thing. I have tried googling and looking through the User Guide, but TI descriptions of the functions are very generic.
Has anyone got this to work with the dll?
02-12-2019 04:03 PM
Hi Kenny,
I was able to find another forum post that may be helpful to you.
Texas Instruments MSP-Gang430 Gang Programmer
https://forums.ni.com/t5/LabVIEW/Texas-Instruments-MSP-Gang430-Gang-Programmer/m-p/530694
sarahmo
02-13-2019 06:17 AM
I worked with MSP430 gangprogrammer several Years ago.
I made the attached back then. Maybe You can play around with it and solve Your Problem.
BR
02-13-2019 10:17 AM
I am good with programming a unit, it is with reading the contents and verifying it is correct.
The MSPGang_Get_Code_Info seems to calculate the checksum of the file that I load into the programmer, and not the contents of the device programmed. I can use the MSPGANG_Read_Code_File and then the MSPGang_Get_Code_Info, and it provides the checksum of the code, and the checksum matches the checksum shown in the MSP-Gang GUI. However, when I did this, I did not have any device connected to the programmer, so it could not have read out the device.
FYI - I am using a MSP430F2001.
So what I then tried was to use the MSPGANG_Interactive_Open_Target_Device, read the target using the MSPGANG_Interactive_DefReadTargets (Mask: 0x01,Start_addr: 0xFC00,End_addr: 0xFFFF), and then the MSPGang_Get_Code_Info. But this always returns a checksum of 0. I am not sure how to point the MSPGang_Get_Code_Info to the code read from the device, vs the Code loaded from the Read_Code_File.
Is the internal data buffer different than the internal buffer? (see bold text in the description of the two API functions below)
MSPGANG_Interactive_DefReadTargets reads the contents of the selected target devices (one to eight targets) simultaneously from Start_addr to the End_addr and saves it in the internal data buffer
MSPGANG_Read_Code_File reads or appends a code file or reads a password file and saves it in its internal buffer.
02-14-2019 02:38 AM
Kenny.
Frankly, since its been 5 Years+, since I worked with this, i really haven't any clue of how to solve Your problem.
That being said, did You try to look at the .vi I attached?
You can set it up to just verify the content of the MCU againts Your firmware File.
BR Bjarne
